Using a network published variable to control an event structure on the RT side of a RIO
Hi all
Trying to use a network published variable to control the event structure of something in an RT loop of a rio project.
When i try and add an event, it wont let me have access to that variable.
Any ideas?
Maybe create a local variable?
13 hours ago, rscott9399 said:
Hi all
Any ideas?
Generally RT code doesn't have a UI, and as mentioned you have to use a special add-on to use events with shared variables. The usual equivalent is to use a messaging tool to handle communication and generate events in your RT code. I personally use HTTP and/or websockets since its free and there are many clients out there. I believe there is a tcp handler for drjdp's messenger lib (https://sine.ni.com/nips/cds/view/p/lang/en/nid/213091), actor framework has a networking addon, and for quick and dirty, AMC (https://www.ni.com/example/31091/en/) works.
To put it another way, where you might use a UI event (queue) structure on a windows machine, you would typically use asynchronous I/O (eg tcp, udp, serial) to feed a queue on the rt system.
