rscott9399 Posted July 1, 2019 Report Share Posted July 1, 2019 I am working on some legacy code that i did not write. Unfortunatley, the original writer used a shared variable that can be written to in about 500 locations. Just a bool tag to cause an abort. I am getting random aborts and i have no clue which writer is pushing on my network published shared variable. Does anyone know of a way to capture this? There are hundreds of this one abort tag. Its impossible to track which is pushing the tag. Thanks Quote Link to comment
andre@carya Posted July 1, 2019 Report Share Posted July 1, 2019 In case it's possible, haven't tried it myself. You could maybe put that SV in a subVI then search and replace each instance with the built-in search and replace function. Manual would be to tedious. Add a dialog that displays the call chain on abort. Quote Link to comment
