MS Word Find Text Position
Hi again!
I'm having a hard time to get the position of a found text in a Word file. I'm able to use the Report Generation toolkit to search+replace text, but I want to highlight the replaced text one way or another. Using the "track changes" option of MS Word would be the best, but changing the font of the replacement and leaving the original text too would also suffice.
The reason I'm struggling with it is that there are several text to search for and replace and the texts are sometimes contain other search text (so for example I want to replace X01 with Y but X01.01 with Z). This can be solved by sorting the search texts reversed alphabetically.
Since I can only search and replace, I have to turn off Track Changes (because the original text will be found again), and replace the found text with a trackable unique dummy text first, than I have to search and replace those with the original+final texts. This means Track Changes will not be effective (or the user would see the horrid dummy texts too). So I would at least apply a different font to the replacements, but I don't know how to set the "Format" parameter of the Document>Range>Find>Execute method.
A preferred method would be to get found ranges first, exclude found ranges from the next searches, then delete the ranges+insert the search string in place of them. This way the changes of the document would have a very nice highlight.
Thanks for any hints or better approaches in advance!
