Zou Posted July 25, 2019 Report Posted July 25, 2019 It's getting and process redraw message like crazy ! Anyone had this kind of problem before? LabVIEW 2014 SP1, Windows 7 Pro. 64 bit. Tested with LabVIEW 2018 too. Control1.ctlFetching info... Quote
Darin Posted July 25, 2019 Report Posted July 25, 2019 Transparency + overlapping objects can lead to a situation with constant redrawing. In this case (LV14 SP1) I was able to tame it by coloring the housing a solid color and then recoloring it transparent. 1 Quote
Zou Posted July 25, 2019 Author Report Posted July 25, 2019 Is there a way to prevent this ? Or should I check every ctrl ? Quote
Darin Posted July 25, 2019 Report Posted July 25, 2019 Good catch using Spy++ in the first place. Not sure I would check every control, but I have always found gauges and meters to be particularly troublesome, so I would check those. If you ever color a part transparent I would think about checking, but LV has gotten much better in the past decade. Once upon a time I actually used the fact that an overlapped, transparent picture control triggered excessive redraws to "fix" problems with controls which were glitchy from a lack of refreshing. Was this control born in LV14 or was it upgraded from an earlier version? Quote
Zou Posted July 25, 2019 Author Report Posted July 25, 2019 I added this gauge to an existing VI/proj. in LabVIEW 2014 SP1, and then customized it. The VI/proj. was upgraded from LabVIEW 2011 previously. Had a huge performance problem with a translucent button before, so I checked when I have performance issue again. Quote
