Vitali Posted October 8, 2019 Report Posted October 8, 2019 Hi. This is a simple project in which we found a problem. We want to: launch several copies of the incoming VI driver, serving the same devices of the same type. In each copy, the binding of the controls to the required shared variable changes programmatically. Noticed: it is impossible to bind the same type of controls in different copies to different variables. The value of the SV variable binding path for the control from the last copy of the VI is copied to all previous controls. Before you begin, you must deploy the library with test variables. Sincerely, Vitaly. Binding.zip Quote
Aristos Queue Posted October 18, 2019 Report Posted October 18, 2019 This is a question that is probably better posted to https://forums.ni.com where a National Instruments Tech Support Engineer can maybe help you. Quote
