Glen Rivard Posted October 9, 2019 Report Share Posted October 9, 2019 I'm having problems converting an array of enum type. I created a simplified version of the problem and have attached those files to demonstrate the problem. The enum is a strict type def. A single enum is converted to JSONtext string and back without a problem. An array of enum does not convert successfully. Array of Enum.vi Loggin Header Data Selection Typedef.ctl Quote Link to comment
drjdpowell Posted October 9, 2019 Report Share Posted October 9, 2019 That is Issue 34, which will be fixed in the next version. In the meantime, the fix is quite easy and described in Issue 34. Quote Link to comment
Glen Rivard Posted October 10, 2019 Author Report Share Posted October 10, 2019 Thanks for your help! Quote Link to comment
