ShaunR Posted October 18, 2019 Report Posted October 18, 2019 Moderator comment: Discussion started here. On 10/17/2019 at 7:58 PM, Darren said: Nice. However this is mine. Quote
Darren Posted October 18, 2019 Report Posted October 18, 2019 1 hour ago, ShaunR said: Nice. However this is mine. The VI Analyzer has core components installed with LabVIEW, like the UI you're seeing. The VI Analyzer Toolkit is a separate install with 90+ tests, including the Complexity Metrics tests. So you need to install the VI Analyzer Toolkit to see the tests. Quote
ShaunR Posted October 18, 2019 Author Report Posted October 18, 2019 43 minutes ago, Darren said: The VI Analyzer has core components installed with LabVIEW, like the UI you're seeing. The VI Analyzer Toolkit is a separate install with 90+ tests, including the Complexity Metrics tests. So you need to install the VI Analyzer Toolkit to see the tests. I've got it in 2019 but not in all the other versions. Is there a separate test install for each version? Quote
Darren Posted October 18, 2019 Report Posted October 18, 2019 3 hours ago, ShaunR said: I've got it in 2019 but not in all the other versions. Is there a separate test install for each version? Yes, it's a LabVIEW Toolkit, which means you have to install it separately for each LabVIEW you have. Here's the download page where you can get whichever version (and bitness) toolkit installer(s) you need: https://www.ni.com/en-us/support/downloads/software-products/download.labview-vi-analyzer-toolkit.html 1 Quote
ShaunR Posted October 18, 2019 Author Report Posted October 18, 2019 54 minutes ago, Darren said: Yes, it's a LabVIEW Toolkit, which means you have to install it separately for each LabVIEW you have. Here's the download page where you can get whichever version (and bitness) toolkit installer(s) you need: https://www.ni.com/en-us/support/downloads/software-products/download.labview-vi-analyzer-toolkit.html Hmm. No 64 bit versions for 2009-2015. Thanks for the info. Quote
Darren Posted October 18, 2019 Report Posted October 18, 2019 3 minutes ago, ShaunR said: Hmm. No 64 bit versions for 2009-2015. Thanks for the info. Right, VI Analyzer Toolkit 2016 was the first version to officially support 64-bit LabVIEW. For unofficial support in previous versions, we have this resource: https://forums.ni.com/t5/VI-Analyzer-Enthusiasts/Using-the-VI-Analyzer-Toolkit-with-64-bit-LabVIEW/ta-p/3494395 1 Quote
ShaunR Posted October 18, 2019 Author Report Posted October 18, 2019 On 10/18/2019 at 4:39 PM, Darren said: Right, VI Analyzer Toolkit 2016 was the first version to officially support 64-bit LabVIEW. For unofficial support in previous versions, we have this resource: https://forums.ni.com/t5/VI-Analyzer-Enthusiasts/Using-the-VI-Analyzer-Toolkit-with-64-bit-LabVIEW/ta-p/3494395 Thanks.It worked great but I don't think I'm going to go through the other 13 versions and installing it. Quote
