custom control with knob and enum
Is there any way to make a custom control with know as it indicates the states of enum .For example  a knob consists of ON ,OFF , IDLE , RUN and OFF states as ENUM represents those states.
While searching or setting those states, enum should be changed accordingly or vice versa.Any ideas could be appreciable.
You can add text labels to a dial. It does not turn it into an enum but sort of works like you would expect (change the data type to U8).
Edited by Neil Pate
  • Thanks 1
