VI opens FP when it should not
Hello,
Clicking certain VI's in my Project also opens the Front Panel of another VI (it's always the same one that's opened). I only want the Front Panel of the VI I click.
 Anyone knows why this is and what can be done against it?
Thanks in advance.
Edited by matys eikelboom
Sounds like the extra VI that shows up has its "Show front panel when loaded"-flag set.
If you open the VI, select File\VI Properties, and then select the Window Appearance category and click customize you can uncheck that option in the lower left corner. If you do not want it to show itself when it is called either, uncheck the Shwo front panel when called option as well (if not already unchecked).
