Compile VI for a specific target
Hello,
I wrote a VI ("ChangeScript.vi") to change programmatically the script of a "MathscriptNode" inserted in another VI ("MathScriptNode.vi").
Because this simple example is a part of a wider project, after the change of the script formula I need to recompile the VI ("MathScriptNode.vi").
I found the VI method "Compile" http://zone.ni.com/reference/en-XX/help/371361R-01/lvscript/vi_compile058vi/ to do this action, but this method only compile for Windows target.
How I can compile programmatically the VI for the target Linux_x64 (cRIO hw)?
The LabVIEW project (LabVIEW 2018) attached contains the example code.
Thank you,
Francesco
SimpleTest.zipFetching info...
Expand
Anything under My Computer is compiled for the platform you are currently on. For your cRIO I think you need to have it as a target in the project first. Then you can deploy your VI to it.
http://zone.ni.com/reference/en-XX/help/371361R-01/lvconcepts/adding_targets_to_project/
 Not that I have ever done this 🤷‍♂️
In a Windows system I would like to open a VI, modify it and finally compile it (only this VI) for a different target, for example Linux x64 (cRIO hw).
This is my desire, but I don't found a right method to reach the goal.
When you a create a Build Apecification under a Target in a Project, LabVIEW on Windows OS compiles all the VIs added to the Build Spec for the specific target. So LabVIEW can cross-compile a VI.
I'm wondering if the cross-compile functionality is provided with some function/method exposed.
Expand
Expand
Move the VI to a cRIO target in your project (there is probably a way to do that with scripting somehow). The compiler will take care of the rest.
Expand
Yes, you can compile VIs for very specific targets like cRIO because it is a well defined environment. However, it is not possible to cross-compile applications between Windows, Linux and MacOS if that is what you want: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P81NSAS
