Calling external DLL fails
I am trying to use an external DLL with LV.
This DLL is known to work with VB and C++; however, when I call it LV traps a low level memory corruption error and stops the VI.
What might be the problem - or what am I doing wrong?
Gyc
maybe the wrong calling convention in the function prototype ?
maybe i can help, if you post the code and the function prototype ?
cheers,
cb
cheers,
cb
5236[/snapback]
Here's the prototype:
int ADAMTCP_Connect(char szIP[],
unsigned short port,
int iConnectionTimeout,
int iSendTimeout,
int iReceiveTimeout);
Download File:post-2388-1120680769.vi
I tried to pass the string as "handle" and as "handle pointer" but it doesn't work: LV is just kicked out with absolutely no messages.
Thanks anyway!
Gyc
5239[/snapback]
That's because the DLL does NOT expect a LabVIEW handle or even a pointer to such. Instead it expects a pointer to a C string.
char somevar[]
is equivalent to
char *somevar
as far as the C compiler is concerned. This is definitely a C string pointer. Configure the Call Library Node parameter accordingly and you should be fine. A LabVIEW string handle or pointer to such can only ever be used for DLLs which have been explicitedly developed to be called by LabVIEW.
Rolf Kalbermatter
