Ansible Posted October 2, 2020 Report Posted October 2, 2020 I think I have nailed converting every other curl command to LV native. This one has me stumped and it should be real easy. cul --location -H "x-file-format: <FILE>" -H "x-campaign-name: TEST_CAMPAIGN" -H "x-session-name: TEST_SESSION" -H "x-description: DESCRIPTION" -H "x-tags: cc13,test" -H "x-notify-email: user@company.com" --form file=@/data/file.file http://URL Also this would help on a little script that I am hoping to release at some point. Given the number of curl examples on the internet made a parser that will generate a vi from a curl example. Quote
Rolf Kalbermatter Posted October 4, 2020 Report Posted October 4, 2020 On 10/2/2020 at 6:28 PM, Ansible said: I think I have nailed converting every other curl command to LV native. This one has me stumped and it should be real easy. cul --location -H "x-file-format: <FILE>" -H "x-campaign-name: TEST_CAMPAIGN" -H "x-session-name: TEST_SESSION" -H "x-description: DESCRIPTION" -H "x-tags: cc13,test" -H "x-notify-email: user@company.com" --form file=@/data/file.file http://URL Also this would help on a little script that I am hoping to release at some point. Given the number of curl examples on the internet made a parser that will generate a vi from a curl example. Expand Sorry I'm not a curl expert. So you could you explain a bit what all these parameters mean and which of them causes problems? Quote
Ansible Posted October 19, 2020 Author Report Posted October 19, 2020 I ended up just using curl CMD which works on both linux and windows. Quote
