SnelleJelle Posted April 2, 2021 Report Posted April 2, 2021 I'm encountering an issue when extracting a zip file that contains a file bigger than 2GB During the creation of the >2GB file, error 4 is thrown after 2 097168kB. source: Set File Position in ZLIB Read Compressed File__ogtk.vi->ZLIB Get File__ogtk.vi->ZLIB Extract All Files To Dir__ogtk.vi->main.vi I'm using LV 18.0.1f4(64bit) The lib version is: LabVIEW ZIP library, version: 4.2, Dec 2018 zlib version: 1.2.11, build flags: 0x2000065 minizip version: 1.2.0, September 16th, 2017 aes version: 2013 bzip2 version: 1.0.6, 6-Sept-2010 Could there be something wrong in my configuration? Am I doing something wrong? Or is this a limitation of the lib? Kind regards Jelle Quote
hooovahh Posted April 5, 2021 Report Posted April 5, 2021 Here is a discussion about it on LAVA. If this is on Windows I'd suggest trying a different compression tool like 7zip or the native zip to see if it will work for you. Quote
SnelleJelle Posted April 12, 2021 Author Report Posted April 12, 2021 Hi Hooovahh, Thanks for the feedback. I started a new issue because I was hopping that this was a new easy to fix issue. But as the last update is from 2015. I will go for the suggestion you made. My application is working on a windows as well on linux (cRio). What will makes i probably a little harder. Kind Regards Quote
