machine vision application
Hi There,
I am working on a LabVIEW project which is a machine vision application
I used a tab control  (3 pages).
1st page for the login interface ( press login button to go next page)
the second page is where I have to select the server ( image processing (page 3) ) and client ( another vi  receive data from the server via TCP/IP (localhost))
page 3 as I said  contains image processing
so my problem is when I open the client I can't use it until I close the first app
maybe the images will clarify better
  On 5/27/2021 at 1:22 AM, Francois Normandin said:
Hi Makrem,
my guess is that your top-most VI is set to be "modal".
https://labviewwiki.org/wiki/VI_class/Front_Panel_Window.Behavior_property
To change the behavior, go to the VI's properties and chose "Windows Appearance". Then select the "default" behavior.
Expand
 thank you sir this is very helpful
the problem solved
