dhendrix11 Posted June 16, 2021 Report Posted June 16, 2021 I'm working on a right click plugin but am running into an issue with grabbing the reference to only 1 item inside a cluster (can be front panel or block diagram constant). If I right click a single item inside a cluster, the right click 'Affected Items' returns 2 references: the reference to the item I selected as well as the parent cluster. However, if I multi-select 2 (or more) items, I do not get the parent cluster reference returned. It could be two items within a single cluster, or any two items at all. 'Affected Items' returns only 2 references. Best I can tell, it's impossible to identify when only a single cluster item was selected for right click manipulation. Bug, or am I missing something? LabVIEW 2019. Quote
Pipaliya Ritesh Posted June 28, 2022 Report Posted June 28, 2022 (edited) I m facing the same issue. but in my case, I also got 2 "affected item" references : the reference to the item I selected as well as the parent cluster. So I always prefer 2nd number of reference because first reference is of the parent cluster. But When I use single or multiple objects in cluster and perform right click on first object (order wise first )of cluster then I get "affected item" object reference on first number of affected items. And for other objects in cluster I get "affected item" object reference on last number of affected items. Edited June 28, 2022 by Pipaliya Ritesh Quote
Pipaliya Ritesh Posted June 28, 2022 Report Posted June 28, 2022 did you find any solution for this issue?? If yes, than can you describe it in here. I m using LabVIEW 2016. Quote
Darren Posted June 28, 2022 Report Posted June 28, 2022 This utility VI is helpful for filtering out only contained controls in a right-click Affected Items array. [LabVIEW 20xx]\resource\plugins\PopupMenus\support\Filter For Contained Controls Only.vi Many of the shipping right-click plugins use this VI for the exact purpose you describe... for example, check out the source code for the Change To Array Or Element plugin: [LabVIEW 20xx]\resource\plugins\PopupMenus\edit time panel and diagram\Change To Array Or Element.llb\Change To Array Or Element.vi 2 Quote
Pipaliya Ritesh Posted September 5, 2022 Report Posted September 5, 2022 @Darren Thanks for the response. I have done it by some other way as I want to track only some particular objects from cluster. but I will surely try by using above shared VI. Quote
