Popular Post hooovahh Posted September 22, 2021 Popular Post Report Posted September 22, 2021 I like resizable UIs, and that often means custom code to handle some of the operations in the UI. One such feature I like is a vertical array, that shows more rows, as the window size gets larger and can show more. I've used code like this a few times and figured the community might like it too. When doing this there are times when I want a user to be able to add more rows, and some times that it needs to either be static, or set by some other outside variable. So in this demo is also a way to link a vertical scrollbar that is a separate control, and have it move, and get set, so that it looks like it is linked to the array control. But this will coerce, and not allow more rows to be seen, than the number of elements in the array. At the moment this only supports 1D arrays, and only in the vertical direction. Code is saved in 2020. Array Resize and Scrollbar Link.zip 2 1 Quote
