Bjarne Joergensen Posted September 23, 2021 Report Share Posted September 23, 2021 (edited) NI-5124 PXI oscilloscope failing. 1. It’s placed in a system that has run for 20 years on Windows XP and Labview 8.2.1 2. PXI rack 1045 3. Mxi: PXI-MXI-4 (PCI-8336 and PXI-8336) 4. Now the PC is upgraded to a new one with Windows 10 and LV15. 5. After new PC the system started, I can see all cards in PXI rack in MAX 6. I can communicate with all card but not NI5124 Scope. 7. When I try to launch Testpanels for Ni5124 I got the following error: Image "Briton_0.png" 8. I can launch Testpanels when I point at NI4070 DMM in MAX. I can then open a new fan and choose Oscilloscope 9. When pressing Run/Stop I got this error: 10. NI MAX pictures: MAX can´t recognize the type of the PXI bridge, but it is a PXI-MXI-4 (PCI-8336 and PXI-8336) 11. Error code -1074108967 occurred at an unidentified location 12. I have looked for solution at NI for error -50550 and found this: Solution These error codes indicate fairly general problems that can be caused by either hardware or software. You can resolve these errors through one of the troubleshooting steps below: Reset the device in Measurement & Automation Explorer, then try the self-calibrate again. Reboot the PC or PXI controller. Try a different PCI or PXI slot. If you are using a remote controller (i.e PCIe-8361) make sure the MXI card has the DIP Switch in the correct position, either ON if you are using BIOS Compatibility Mode or OFF if you are not. I have tried 1, 2 and 3 => did not help. About 1 Reset and Self-test is success but Self- Calibrate is just running for ever. @4 If this was not setup correctly, I assume the PC would not be able to see the PXI rack and modules in it. I have tried to delete all LabVIEW and device driver SW on the PC and then installed it again. I still got the same error! What could be my next step? Thanks in advance /Bjarne PS: I also posted the question in NI-forum, but none has responded yet and then I think the hard core fellows at LAVAG could help me https://forums.ni.com/t5/LabVIEW/PXI-NI-5124-error-code-50550/m-p/4180536#M1208650 Edited September 23, 2021 by Bjarne Joergensen Quote Link to comment
Bjarne Joergensen Posted September 24, 2021 Author Report Share Posted September 24, 2021 (edited) Hi Update: Started Self Calibration yesterday afternoon This morning I got this error in MAX: /Bjarne Edited September 24, 2021 by Bjarne Joergensen missing letter Quote Link to comment
Bjarne Joergensen Posted November 10, 2021 Author Report Share Posted November 10, 2021 Hi Sorry the late response. I have been spoken to a NI engineer and it looks like combability problem with the MXI card. It's not supporting Win10. I have ordered new MXI card and I'll went back when I get the new card and I know it has solved the problem. Hopefully ultimo November. Regards Bjarne Quote Link to comment
Gribo Posted November 10, 2021 Report Share Posted November 10, 2021 I have a similar setup (PXI-1045 and NI PXI cards, with PCI-8361 MXI card). Did you see any other incompatibilities? Quote Link to comment
