Using LabVIEW with LINX to control a Raspberry Pi
Oprea
Does anyone have any experience with using LabVIEW with LINX to control a Raspberry Pi?  I'd like to understand how to write LabVIEW code to control devices on the I2C or SPI bus.  I can successfully run LabVIEW code deployed to the Raspberry Pi to control the GPIO digital I/O pins but would also like to write code to control an A/D converter chip.
  • 2 weeks later...
Hi, Jordan.  Do you (or anyone else) know of any additional LabVIEW LINX libraries for Raspberry Pi?  I'm looking for as many different hardware drivers that I can find.
This website is old, but has some information.
https://www.labviewmakerhub.com/doku.php?id=libraries:linx:start
You might also find some useful things here:
https://forums.ni.com/t5/Hobbyist-Toolkit/bd-p/linx-toolkit?profile.language=en
  • 3 weeks later...
Can LabVIEW (via LINX) put data on the virtual front panel of a Raspberry Pi so that an app such as VNC Viewer can see it remotely using any laptop?
No. But you could host a web app and then view it from within the pi in a browser. Here is an example application you may be able to use for inspiration. Credit Sam Sharp I think.
https://www.mediamongrels.com/democracybot-rpi-linx-websockets-nxg-webvis/
Once a LabVIEW application is running (via LINX) in a Raspberry Pi and the application's LabVIEW front panel is actively running on my laptop, if I break the connection between my laptop and the Pi, is there a way to restore the connection without having to re-download to the target my entire LabVIEW code again?
