pandaman Posted August 17, 2005 Report Share Posted August 17, 2005 How would you express exponential expressions using ONLY expression nodes (found in numeric on functions bar)? I have tried 10^x, but the values are not desirable: 1------[10^x]-----11 2------[10^x]-----8 3------[10^x]-----9 4------[10^x]-----14 5------[10^x]-----15 6------[10^x]-----12 I have tried exp(), but it doesn't work... ... Quote Link to comment
Neville D Posted August 17, 2005 Report Share Posted August 17, 2005 How would you express exponential expressions using ONLY expression nodes (found in numeric on functions bar)? I have tried 10^x, but the values are not desirable:1------[10^x]-----11 2------[10^x]-----8 3------[10^x]-----9 4------[10^x]-----14 5------[10^x]-----15 6------[10^x]-----12 I have tried exp(), but it doesn't work... ... 5693[/snapback] Try x**y (where y is the exponent). Neville. Quote Link to comment
pandaman Posted August 17, 2005 Author Report Share Posted August 17, 2005 Try x**y (where y is the exponent).Neville. 5694[/snapback] Wow, it worked! I wonder though why LabVIEW uses ** instead of ^... it would make much more sense to use the former since it works in the Eval f(x) methods. I am very curious as to how ^ operates in expression nodes, since I did receive output. Thanks for the help :worship: Quote Link to comment
AnalogKid2DigitalMan Posted August 17, 2005 Report Share Posted August 17, 2005 ^ may be reserved for bit exclusive or operations Quote Link to comment
pandaman Posted August 17, 2005 Author Report Share Posted August 17, 2005 ^ may be reserved for bit exclusive or operations 5697[/snapback] Oh yea, it's an exclusive OR bit operator.... Quote Link to comment
Neville D Posted August 17, 2005 Report Share Posted August 17, 2005 Wow, it worked! I wonder though why LabVIEW uses ** instead of ^... it would make much more sense to use the former since it works in the Eval f(x) methods. I am very curious as to how ^ operates in expression nodes, since I did receive output.Thanks for the help :worship: 5696[/snapback] No problem. Somewhere in the LV documentation there is a page showing all the operators allowed for the formula node & expression node. N. Quote Link to comment
progor Posted August 18, 2005 Report Share Posted August 18, 2005 you can find it in Help - Precedence of Operators in Formula Nodes and Expression Nodes Quote Link to comment
