Francois Aujard Posted November 15, 2022 Report Posted November 15, 2022 Hello, I had a slowdown in my system due to a type adjustment. And I don't understand why I have this type adaptation. Why is there a red dot on the local variable that reads data from the property node from a reference, and not from its own property node? I've been using this Vi for years, the clusters change but I've never had a problem adapting to the type... An idea? Quote
LogMAN Posted November 15, 2022 Report Posted November 15, 2022 This can happen when a typedef changes from strict to non-strict or vice versa. In this case, the value returned by the property node will remain strict or non-strict, resulting in a coercion dot. Typedef Coercion.mp4 Quote
Francois Aujard Posted November 16, 2022 Author Report Posted November 16, 2022 Not in my case... ☹️ 477650069_2022-11-1609-08-55.mp4 Quote
JKSH Posted November 16, 2022 Report Posted November 16, 2022 (edited) This looks kind of similar to the bug that @Darren talks about in the video below (at 30:44). Try this: Disconnect your "CONSIGNES" terminal from the type def, delete the property node, re-connect the terminal to the type def, and then re-create the property node... does that help? Edited November 16, 2022 by JKSH 1 Quote
LogMAN Posted November 16, 2022 Report Posted November 16, 2022 Re-creating the property node should fix the immediate issue, but it may happen again in the future. 1 hour ago, Francois Aujard said: Not in my case... ☹️ Does your typedef contain sub-types? Changes to nested typedefs can have the same affect. Quote
Francois Aujard Posted November 17, 2022 Author Report Posted November 17, 2022 On 11/16/2022 at 9:29 AM, JKSH said: Try this: Disconnect your "CONSIGNES" terminal from the type def, delete the property node, re-connect the terminal to the type def, and then re-create the property node... does that help? @JKSH yes, it solved my problem ! Thank you. On 11/16/2022 at 11:09 AM, LogMAN said: Does your typedef contain sub-types? @LogMAN No. I followed the advice of @JKSH and my problem has disappeared. It's a Labview Bug... Quote
