A nearly native tiff reader and writer
I want to share my tiff reader and writer, maybe someone finds it useful. It supports only a subset of the tiff format (like most). It is native, but uses openg's zip and g-image for jpeg compression.
I tested in in my use cases, but there will still be bugs and unsupported features. Please post issues at github.
If your are interested, visit https://github.com/kleinsimon/LV-Tiff
Edited by spaghetticoder
Typo
I just moved it to Code In Development.  I haven't tested this but native TIFF is pretty neat.  When you feel development is in a good place you should post your package on VIPM.IO. Then it will show up in VIPM.  The process for uploading packages is pretty straight forward, and you can link back to the Git for the source.  In my Image Manipulation package there is a Load Image function which accepts TIFF.  It also allows you to select which image from within the file if there are multiple in there.  This all uses .Net image library and is less native, being restricted to Windows.
