JESENDI JESNER Posted June 10, 2023 Report Posted June 10, 2023 Good day, I am struggling to make a code for a precision voltage source. Do you have any examples that I can use as a reference? I am using LabVIEW 2013 to a DAC AD5791 with NI PXIe HSDIO as its inputs. Your help will be appreciated. Thank You. Quote
Gribo Posted June 12, 2023 Report Posted June 12, 2023 What did you do till now? Can you post your code? Quote
infinitenothing Posted June 14, 2023 Report Posted June 14, 2023 I'm curious why you went with the 6556. I probably would have gone with a LINX solution. Anyhow, I did a little searching and it looks like there's a SPI library/examples for that card. https://forums.ni.com/t5/Digital-I-O/SPI-Communication-using-PXIe-6556/td-p/3591472 Quote
JESENDI JESNER Posted June 15, 2023 Author Report Posted June 15, 2023 6556 is the only resource that I have. ill try to recreate the code on the link. Thank you so much. Ill update you if it worked. Quote
