LabVIEW example code , Fusebox Inspection Example
Anybody can help me to get the Fusebox Inspection example code (.vi format) .
This code can get it from Labview library.
You can also search this file in Labview > help > find example > searching...
The file location is LabVIEW\examples\Vision\3. Applications\Fusebox Inspection Example.llb .
Another example is "Tile identification" . I am not sure the file location for this.
Thank you.
The whole examples folder from VDM for LabVIEW 2010.
examples.rar
Couldn't find any VI with the same or similar name.
Edited by dadreamer
Hi, Dadreamer,
Thank you for your helps.
Can you teach me how to use below 2 files ?
For your information, i am a Labview beginner user so not so familiar with LABVIEW program.
Thank you.
best regards.
Edited by Jeffrey Oon
There's nothing special about these two VIs. They are just helpers for the higher level examples. You don't need to run them directly. In real life projects you won't need those VIs at all.
What about taking some image processing and machine vision courses?
Edited by dadreamer
