Norbac Posted September 15, 2005 Report Share Posted September 15, 2005 Hi everybody, is there a way to pause a Timer Loop in LV 7.1 or stop and start it again? If someone knows how to do that please let me know. Thanks AV Quote Link to comment
Neville D Posted September 15, 2005 Report Share Posted September 15, 2005 Hi everybody, is there a way to pause a Timer Loop in LV 7.1 or stop and start it again? If someone knows how to do that please let me know.Thanks AV What do you mean by Timer loop? You can use the "timed loop" structure which can be stopped and restarted as well. Neville. Quote Link to comment
peteski Posted September 15, 2005 Author Report Share Posted September 15, 2005 Hi everybody, is there a way to pause a Timer Loop in LV 7.1 or stop and start it again? If someone knows how to do that please let me know.Thanks AV Norbac, If you are using "Timed Loops", have a look at this. The "mode" you set for the timed loop in this case is critical and should be considered in light of your specific application. Hope this helps, -Pete Liiva Download File:post-2931-1126804296.vi Quote Link to comment
