Deleting Execution Target addresses
Folks,
I've looked through all the documentation I could muster to look through, but couldn't find a "published" method to delete "obsolete" Execution Target addresses.
post-2931-1127229344.png?width=400
I ran into this problem recently as I have been becoming familiar with Labview's Real Time ETS on PCs. I started by working with PCs with particular IP addresses and then decided to change all of the IP addresses - to protect the innocent ;) Unfortunately, the old IP addresses remained in the list of Execution Target addresses, even though I had no use for them anymore.
Eventually, I decided to roam about in the Labview.ini file - a neighborhood I don't often cruise through. I found the addresses hiding in there, and deleted them.
post-2931-1127229556.png?width=400
This seemed to do the job just fine, although it would have saved me some searching if it was documented somewhere. Or maybe it is documented, but somehow I missed it. Has anybody else been through this?
-Pete Liiva
