王佳 Posted March 27, 2024 Report Posted March 27, 2024 Can you please tell me how to implement this kind of control with transfer function in FPGA module? I can't find any function about transfer function in FPGA! Thanks a lot guys! Quote
infinitenothing Posted March 28, 2024 Report Posted March 28, 2024 I don't think you're going to find an easy way to transfer this automagically to FPGA. You're going to have to break it down into developing your own nth order derivative and integral functions. Are you using compact RIO? If you don't need a crazy fast loop rate, you should be able to simulate your FPGA code as HIL running in RT which would make the development a little faster. Quote
王佳 Posted April 6, 2024 Author Report Posted April 6, 2024 On 3/29/2024 at 12:50 AM, infinitenothing said: I don't think you're going to find an easy way to transfer this automagically to FPGA. You're going to have to break it down into developing your own nth order derivative and integral functions. Are you using compact RIO? If you don't need a crazy fast loop rate, you should be able to simulate your FPGA code as HIL running in RT which would make the development a little faster. Thank you very much for your reply! I'm using a compact RIO.I have to implement this control algorithm on the FPGA side. May I ask how this is realized as you said( break it down into developing your own nth order derivative and integral functions) Can you give me a simple example? thanks.😃 Quote
王佳 Posted April 8, 2024 Author Report Posted April 8, 2024 On 3/29/2024 at 12:50 AM, infinitenothing said: I don't think you're going to find an easy way to transfer this automagically to FPGA. You're going to have to break it down into developing your own nth order derivative and integral functions. Are you using compact RIO? If you don't need a crazy fast loop rate, you should be able to simulate your FPGA code as HIL running in RT which would make the development a little faster. Can I use this module directly? Is it possible to implement a control algorithm by discretising all the transfer functions in the graph and representing them with this module? Quote
infinitenothing Posted April 17, 2024 Report Posted April 17, 2024 I don't quite recognize that node. It looks a bit like a delay node. Regarding the transfer function, you can always use something like the central difference to approximate the derivative and simpson's rule to approximate an integral. Once you have those, you can take the derivative of the derivative to get the higher order derivatives and so forth. Here's an example using slightly simpler approximations: Quote
王佳 Posted April 18, 2024 Author Report Posted April 18, 2024 15 hours ago, infinitenothing said: I don't quite recognize that node. It looks a bit like a delay node. Regarding the transfer function, you can always use something like the central difference to approximate the derivative and simpson's rule to approximate an integral. Once you have those, you can take the derivative of the derivative to get the higher order derivatives and so forth. Here's an example using slightly simpler approximations: Firstly, thank you very much for your reply. Please forgive me for uploading the wrong image, what I meant to upload was actually this. Its name is Discrete Transfer Function Direct VI. Also could you please tell me which transfer function is expressed in the example you gave? I'm sorry. I'm probably stupid. Quote
