Question on "Finding a missing subVI in a referenced VI"
When I use "Open VI Reference" to run a VI file, LabVIEW looks for subVIs when there is a subroutine in the called VI file. When I run this program in RunTime, it says that the subVIs are not found, but I can find the missing subVIs in the development environment, I want to know how to set the path of RunTime to find the subVIs.
Use the File Dialog express VI on the File IO >> Advanced  palette.  You can configure this to prompt the user for a file path then wire that into the open.
Thanks, I've solved that problem.
