김진철 Posted April 12, 2024 Report Posted April 12, 2024 Hello, I would like to save parameters for UI elements and load them when the program exits. What's the easiest way to do this? I think UI element parameters might include things like the color and thickness of graph lines, tab positions, and the maximum and minimum Y values for the graph. Quote
bbean Posted April 12, 2024 Report Posted April 12, 2024 On 4/12/2024 at 2:38 AM, 김진철 said: Hello, I would like to save parameters for UI elements and load them when the program exits. What's the easiest way to do this? I think UI element parameters might include things like the color and thickness of graph lines, tab positions, and the maximum and minimum Y values for the graph. Expand you could try this property saver. its pretty old. See the examples in the palette that gets installed konstantin_shifershteyn_lib_property_saver-1.5.0.4.vipFetching info... Quote
