regisphilbin Posted September 28, 2005 Report Posted September 28, 2005 I'd be interested in having a property node element for the blink rate or flash rate of certain controls. Quote
vikas Posted September 29, 2005 Report Posted September 29, 2005 I'd be interested in having a property node element for the blink rate or flash rate of certain controls. Why do you want proprty nodes ? try with this; go to Tools>>options>>Front panel to change blink speed. Tools>>Options>>Colors to change the color of blinking ---- Vikas Quote
Yair Posted September 29, 2005 Report Posted September 29, 2005 Why do you want proprty nodes ? A. Because it allows you to manipulate each control individually. B. Because to import those settings into an EXE you need to redefine them or put them into the INI file, which is annoying. But mostly because of A. I agree, this would definitely be a nice feature. In fact, I think that almost anything that can be set through menus should also be set through property nodes. Quote
BChandler Posted September 29, 2005 Report Posted September 29, 2005 A. Because it allows you to manipulate each control individually.B. Because to import those settings into an EXE you need to redefine them or put them into the INI file, which is annoying. But mostly because of A. I agree, this would definitely be a nice feature. In fact, I think that almost anything that can be set through menus should also be set through property nodes. You can do this now by writting your own code to periodicly change the Color or invert the Visible property. (or make it dance around and scream LookAtMe etc.) I've done this before (invert Visible each loop) to bring attention to a major alarm. You could even hide it all a sub-vi with just the control's reference for an input. More flexible and more fun than waiting for NI to get around to it. I agree with the last statement. The program should be able to do anything the operator can do. Should be one of NIs golden rules. -WDC Quote
regisphilbin Posted September 30, 2005 Author Report Posted September 30, 2005 You can do this now by writting your own code to periodicly change the Color or invert the Visible property. (or make it dance around and scream LookAtMe etc.) I've done this before (invert Visible each loop) to bring attention to a major alarm. You could even hide it all a sub-vi with just the control's reference for an input. More flexible and more fun than waiting for NI to get around to it.I agree with the last statement. The program should be able to do anything the operator can do. Should be one of NIs golden rules. -WDC We are currently using a SubVI for this functionality but thought it would be useful to be included into the control. Quote
