sam Posted June 1 Report Share Posted June 1 (edited) It's been a while I've worked on sbRIO devices. usually MAX is how you setup the sbRIO but that options seems to be gone. Am I missing something? this sbRIO had 2019 on it before I formatted the drive , now I can browse to it but options to install are no longer present. I downloaded System Configuration/setup from NIPKG manager and all *.ipk files but a bit lost on how I can put an OS on this sbRIO. Any help is appreciated. Editing to add: Some information on only LabVIEW 2019 and older can be installed the old way https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DthyCAC&l=en-US 2020 and newer installation is done differently. What I'm concerned is if all sbRIOs are supported with new method. I'm guessing not https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2jQCAQ&l=en-US end of edit. Edited June 1 by sam Link to comment
Rolf Kalbermatter Posted June 2 Report Share Posted June 2 On 6/1/2024 at 12:36 PM, sam said: It's been a while I've worked on sbRIO devices. usually MAX is how you setup the sbRIO but that options seems to be gone. Am I missing something? this sbRIO had 2019 on it before I formatted the drive , now I can browse to it but options to install are no longer present. I downloaded System Configuration/setup from NIPKG manager and all *.ipk files but a bit lost on how I can put an OS on this sbRIO. Any help is appreciated. Editing to add: Some information on only LabVIEW 2019 and older can be installed the old way https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000001DthyCAC&l=en-US 2020 and newer installation is done differently. What I'm concerned is if all sbRIOs are supported with new method. I'm guessing not https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x2jQCAQ&l=en-US end of edit. You consequently have hidden the actual type number of your sbRIO in your pictures. I think I can see in one place a 963x but it is not sure. And most 963x except the 37 and 38 are VxWorks based and as such LabVIEW 2019 is the latest to support that. It also requires you do install CompactRIO software not later than 19.6. The 9637 is supported since LabVIEW 2015 and CompactRIO 15.5, but the 9638 requires at least LabVIEW 2019 and CompactRIO 19.5. Link to comment
sam Posted June 2 Author Report Share Posted June 2 Thanks Rolf, I put 19 back on it. Link to comment
Please sign in to comment
Sign In Now
