Can someone helps me how to store data in one field?
wyyew
hi all i got a problem of storing data into one field.
i want to do something like
1st time x=12, y=34
2nd time x=56 , y=67
i need to store this value into array once the program start.
such as below in array
x y
12 34
56 67
problem: because i get a list of same value in the array.
post-2684-1128081361.gif?width=400
1st time x=12, y=34
x y
12 34
56 67
You can also define a constant 2d array by putting an array object on your block diagram then placing an I32 number in it. Drag the index control downwards to make it 2d, then drag the edges of the array to increase the number of visible elements, then type in your values.
Neville.
Neville.
nope I hope to do like something autoindexing
1st my x and y will automatically refresh
array index x y 2d array
1 13 15
2 66 77
