LabView 8: Auto grow bug with flat sequence
ooth
Structures (For Loops, While Loops, etc) will auto grow when you resize another structure that is inside it. This happens for all the structures except the Flat Sequence. Drop a For Loop on the diagram and then put a Flat Sequence in it. Grab the bottom edge of the sequence and resize it so it extends out of the For Loop. The For Loop won't grow! But it will grow if you use any of the other structures instead of the Flat Sequence. The thing is that I tried this in LABVIEW 7.1 and the loop did grow! So is this a bug in 8?
Yep, it's a bug.
