RaviPaike Posted November 24, 2005 Report Posted November 24, 2005 In Labview is it possible to make transperant lable on the front panel like a watermark in the wrod doc. how can I do that. Thanks in advance Ravi Quote
Mike Ashe Posted November 25, 2005 Report Posted November 25, 2005 Select the label, select the color tool, right click on the label and in the color box select the " T " for transparent. No border, no background color. If you want you can then select the text tool, highlight/select the text in the label and go to the Text Settings menu >> Color and in the color box set the text color so that it is just barely visible, or even invisible for that matter. You can later select the text to see the letters. Quote
alphaone Posted November 25, 2005 Report Posted November 25, 2005 In Labview is it possible to make transperant lable on the front panel like a watermark in the wrod doc. how can I do that. Thanks in advance Ravi Or, Tools->Option->Front panel, check the "Use Transparent Name Label". Quote
