Jack Kelledes Posted November 28, 2005 Report Posted November 28, 2005 I wrote a fairly simple application for an engineer at my work who passed it on to his customer in Sweden. The problem is that if the region setting on their PC is set up for Sweden all the numbers get messed up. Decimals go away (Sweden uses commas) and some calculations don't work, especially those with exponents. I didn't know this would happen at all, thinking that numbers were pretty much universal. I know there are users here from Europe which is shy I didn't think about it being a problem. I have not been able to find anything on the message forums about it. Is there a way to simply change this application from English to Swedish or do they have to live with their PC set to English? Thanks, Jack Quote
malef Posted November 29, 2005 Report Posted November 29, 2005 Jack, have a look at Front Panel Options Page. "Use localized decimal point Quote
Jack Kelledes Posted November 29, 2005 Author Report Posted November 29, 2005 Manfred, Thanks for the reply. Unfortunately it didn't work. I removed the checkmark in LabVIEW like you said. I then rebooted (just in case) and rebuilt the application into an EXE and the same thing still happens. I tried a bunch of stuff and noticed that the only thing that matters is the decimal point. If I change the decimal in the Swedish region settings to a period everything works fine. If I leave it a comma it goes wacky again. Right now I'm changing the region of my development computer to Swedish and and then going to rebuild the EXE to see what happens. Thanks again. Jack Quote
jpdrolet Posted November 29, 2005 Report Posted November 29, 2005 Manfred,Thanks for the reply. Unfortunately it didn't work. I removed the checkmark in LabVIEW like you said. I then rebooted (just in case) and rebuilt the application into an EXE and the same thing still happens. I tried a bunch of stuff and noticed that the only thing that matters is the decimal point. If I change the decimal in the Swedish region settings to a period everything works fine. If I leave it a comma it goes wacky again. Right now I'm changing the region of my development computer to Swedish and and then going to rebuild the EXE to see what happens. Thanks again. Jack You don't need to rebuild the application to change the decimal setting since it is an application option that is stored in its ini file. The ini key to force the use of the decimal point is: useLocaleDecimalPt=False Set it to True and the application will use the local (swedish) comma. By forcing LabVIEW to use decimal point, that should solve your problem. However, the best solution is to revise your code so that your application is independant of the local setting for the decimal separator. Use the format specifiers "%.;" (use point) "%,;" (use comma) or "%;" (use system) to force the separator when it is needed, for example reading the numeric reply from an instrument or reading a spreadsheet file. Quote
Jack Kelledes Posted December 14, 2005 Author Report Posted December 14, 2005 Sorry it took so long to post back but the LabVIEW .ini key does the trick! I sure wish there was more written on what you can put in that .ini file. The problem with this software was I didn't write most of it, just modified some parts to work with a slightly different configuration than the original software. Whoever wrote it initially took the long way around (looks like they just experimented until they got it to work right) to get most of the stuff done and it was also "proprietary" so I couldn't really do much with it without getting someone upset with me. I guess without realizing it I have been doing my vi's the way that jpdrolet suggests and have not had any problems. The majority of the problems I'm called on to "fix" are because someone's software is being used on something it wasn't written for and the engineers think it's easier to just modify that code than it is to write some from scratch. Thanks again for the help. Jack Quote
