DAQmx Base Read (Analog 2D DBL Nchan NSamp)
decyL
In this block error occurs after build. Has anyone got an idea what happens? Greetings, I will be grateful for any kind of clues, hints and tips. - error is: given session or object reference is invalid
  • 3 months later...
I'm having the same problem - I create a very simple VI (DAQmx read in a loop - output to a chart):
post-181-1143480568.jpg?width=400
and I create the channel in my LabVIEW 8 Project. When run in the LabVIEW development environment it works fine
post-181-1143480338.jpg?width=400
but once built I get error -200428 "Value passed to the Task/Channels In control is invalid. The value must refer to a valid task or valid virtual channels."
post-181-1143480396.jpg?width=400
Anyone got any ideas? (I've attached the full project in a zip)
Download File:post-181-1143480404.zip
I posted this to Info-Labview
Chris
It appears to be a permission problem... if you copy the nidaqmx.ini file to c:\ and edit the "NI-DAQmx.ApplicationStorageFile" parameter in the apps .INI file to point to the c:\NI-DAQmx.ini , it should work.
Dan
Also from Info-LabVIEW: Thanks for the suggestion Dan - it cleared my mind! :) Actually, it's not a permissions issue, it's that the builder creates the wrong path in the application's .ini file - my NI-DAQmx.ApplicationStorageFile was set to "applicationfolder\nidaqmx.ini", where it should have been just ".\nidaqmx.ini" - looks like a bug to me!
Good catch. We have verified that this is in fact a bug with the ways in which paths are formed in certain situations. We are looking into a solution to this issue and hope to have it resolved in a subsequent DAQmx/LabVIEW release. In the mean time there are two ways to work around this bug
1. Modify the build spec's "Destinations->Support Directory" to be a sub-directory of the
"Destinations->Destination Directory" location. "data" is the default sub-directory
when a build spec is created.
2. After building the app, hand edit the <application name>.ini file and change
the NI-DAQmx.ApplicationStorageFile key to be an absolute path to the .ini file or a relative
path to the .ini file without a ".\" before the path
Great - can you please provide a CAR number so we can track it here?
  • 2 months later...
Hey Chris - any progress on that CAR? Or better yet - any progress on a bug fix :)
  • 2 months later...
This bug has been fixed in LabVIEW 8.20 and NI-DAQ 8.3.
Installing NI-DAQ 8.3 and using it a version of LV < 8.20 will still show the problem. Using a version of NI-DAQ < 8.3 with LV 8.20 will also show the problem.
That's great news (and just in time for my project too) - thanks so much for keeping us updated!
