LAVA 1.0 Content Posted December 6, 2005 Report Posted December 6, 2005 :arrow: I have stuck up with writing the files in the LabVIEW, i want to do the Fifo(First in First Out) while writing One continuos file to .lvm type, I cant do this with options of the LabVIEW, can anyone suggest me how can I do that? please give me the solution. :headbang: Quote
Jim Kring Posted December 10, 2005 Report Posted December 10, 2005 :arrow: I have stuck up with writing the files in the LabVIEW, i want to do the Fifo(First in First Out) while writing One continuos file to .lvm type, I cant do this with options of the LabVIEW, can anyone suggest me how can I do that? please give me the solution. :headbang: A file is a FIFO, if you read it from front to back and append data to the back. However, you should look at the Queue as a way of doing a FIFO. Why are you using a file as the FIFO? Are you sharing the data between two applications? You say that you can't do what you want with the options in LabVIEW; but which approaches have you tried? Show us some examples of your code, where you are getting stuck. Quote
