how to implement lookup tables?
xolstis
Hi there, am rather new to labview. Have been looking high and low for some kind of look-up table function that I might be able to implement in labview unsuccessfully.
I need to be able to have a 2D table that gives out a single output taken from the table for a given set of two input variables. Anway to do this easily?
Cheers
Cheers
Go to NI.com and in DevZone search for Parse Lookup Table
or try here: Parse Lookup Table
Cheers :beer:
Cheers
Here is an implementation of a lookup table. The LUT can be either:
- a 2d array of X-col, Y-col,
OR
- a 1d array of (X,Y) clusters.
Given an X, it will interpolate a Y value. Note that the LUT must be monotonically increasing for the LV function to work!
You can add additional logic to check for out of range X values, error generation, interpolating Y given X etc. as needed.
Cheers,
Neville.
Download File:post-2680-1134673935.vi
OR
Cheers,
Neville.
Hi Neville,
Have looked at the vi you attached. Correct me if I am wrong but it appears that this vi does something like curve fitting. As in given a graphical function (or in this case by interpolating a series of points on an array), the function returns a value of y for an input of x. Not too diff from say if you had a graph of y = 2x this function simply tells you what y is for a given value of x except in this case no graphical function is given but rather a 1D array is used.
If I am correct in my conclusion this isn't quite what I need because the values I have to fit into the table will probably not fit into any function or curve. Have attached a picture to illustrate what I am trying to do. It sounds really simple but I can't seem to find a simple solution for it.... I am sure there is one and its just eluding me. The parse lookup table suggestion by Michael looks a little complicated :) am trying to look thru it now to see if it does what I require.
Thanks for the help.
post-3705-1134699115.jpg?width=400
