Khalid Posted January 20, 2006 Report Posted January 20, 2006 Hi, In 7.1.1, should we be able to create executables when using scripting nodes? I get the following error when I try to run the executable created this way: "This VI is not executable. The full development version of LabVIEW is required to fix the errors." If I remove those VIs which have scripting nodes, the executable works just fine. I even tried placing the SuperSecret... entry in the ini file for the built app. Doesn't help. Any ideas? -Khalid Quote
Jim Kring Posted January 21, 2006 Report Posted January 21, 2006 Scripting requires the editor and is not supported in the run-time engine. This will not work using remote application references to a LabVIEW Development Environment, either. Quote
