golzio Posted February 8, 2006 Report Share Posted February 8, 2006 Is there a way to programatically reorder controls in cluster?? Thanks in advance Alessio Colzi Quote Link to comment
yonatan.tidhar Posted February 8, 2006 Report Share Posted February 8, 2006 take a look at openG "Write Panel to INI.vi", "Write Panel to INI.vi" Quote Link to comment
PJM_labview Posted February 11, 2006 Report Share Posted February 11, 2006 Is there a way to programatically reorder controls in cluster??Thanks in advance Alessio Colzi If by reorder you mean change the order like you do in the editor (right click > reorder controls in cluster), then no, you cant do that programatically. But, you can always move the objects inside the cluster programatically (if you do that, make sure the cluster does not have "auto size" on). PJM Quote Link to comment
