Align Control in SubPanel
Vladimir
Hi all there,
I have very simple problem - I mean...
I have TopVi with Sub Panel. In Sub Panel SubVi will be shown. I want align one of SubVI control to upper-left corner in Sub Panel.
I can obtain Position property of this control, but what next ? I trying to set SubVI->FrontPanel->Position property, but with unexpected result. I mean this is not the right way :nono: or I miss the point.
Why I need this: I want to have code where saving SubVI front panel position does not have influence to TopVi look.
best regards, Vladimir
I don't have LV8, so I can't look into your code.
But usually to set an alignement on a panel use the property "Front Panel Window>Origin". It sets the coordinate you supply to the top-left corner.
Seems logic, but here is no property caled Origin in Front Panel reference... :headbang:
Did NI remove this (IMHO) useful property in LV8? :blink:
It seems more likely to me (from his descriptioin) that Vladimir tried to wire the Panel reference to a property node instead of looking through the Front Panel Window properties.
:thumbup: Very Nice, now working well,
Thank you Joe !
Working wersion is included:Download File:post-3852-1139983403.zip
Glad it worked out. I'll file it away to look at when I upgrade to 8.0 (hopefully next month).
I assume this would be one of those times where you won't be able to save to a previous version (7.1), since it uses version specific pane properties(?) :unsure:
Joe (orko)
