cosmin Posted February 10, 2006 Report Posted February 10, 2006 Hi all, I use scripting to create a graph control and a while loop in digram. How can I move in the diagram the graph terminal into the while loop? thanks Quote
Jim Kring Posted February 10, 2006 Report Posted February 10, 2006 cosmin said: Hi all,I use scripting to create a graph control and a while loop in digram. How can I move in the diagram the graph terminal into the while loop? thanks Use the Move method. Quote
cosmin Posted February 11, 2006 Author Report Posted February 11, 2006 Jim Kring said: Use the Move method. HI, Thanks for the reply, figured out myself after 2min from the post . Now I have another question, anything new with scripting and labview 8? it's a great tool and is funny to get stuck in labview 7 just for scripting thanks Quote
Rolf Kalbermatter Posted February 12, 2006 Report Posted February 12, 2006 cosmin said: HI,Thanks for the reply, figured out myself after 2min from the post . Now I have another question, anything new with scripting and labview 8? it's a great tool and is funny to get stuck in labview 7 just for scripting thanks Yes, scripting is now not anymore controlled with an ini file setting, but through the license manager. (In fact it seems LabVIEW still wants to have an ini file setting but it will only check this setting after you have installed a valid scripting license, and no it is not the same ini file setting as in the past :-( Rolf Kalbermatter Quote
didierj Posted February 13, 2006 Report Posted February 13, 2006 cosmin said: HI,Thanks for the reply, figured out myself after 2min from the post . Now I have another question, anything new with scripting and labview 8? it's a great tool and is funny to get stuck in labview 7 just for scripting thanks Seems we're getting control back: Property and Method Selection... Dynamic Generation of... Quote
Dave Barney Posted February 13, 2006 Report Posted February 13, 2006 Jim Kring said: Use the Move method. Hi I must be missing something but I do not find the "Move" method at all for any invoke node. I am using Labview 7.1 - is it only available in higher versions? thanks in advance for any advice. cheers Dave Quote
cosmin Posted February 13, 2006 Author Report Posted February 13, 2006 Dave Barney said: HiI must be missing something but I do not find the "Move" method at all for any invoke node. I am using Labview 7.1 - is it only available in higher versions? thanks in advance for any advice. cheers Dave The "Move" apears as a method for a "Terminal" reference for a control. We get some new fine tools for Labview 8, but... how can anyone create a shared variable with scripting, in a BD? the New control VI ask for "style". Can anyone post the "styles" for Labview 8, or where are located in the Labview folders? If the Labview 8 is still with the scripting locked, the "vi object class" probably does not show everything. Quote
Jim Kring Posted February 13, 2006 Report Posted February 13, 2006 Dave Barney said: HiI must be missing something but I do not find the "Move" method at all for any invoke node. I am using Labview 7.1 - is it only available in higher versions? thanks in advance for any advice. cheers Dave VI Scripting - Readme First Quote
