facing labview 7 big problem
kjimcarrey
I follow a developed project that use bluetooth for remote moritoring. Then, I duplicate one more circuit borad for running at dual channel. However, i don't know how to run labview to implement dual channel. I mean is it base on the port name to implement dual channel?
please help...!!!
It depends... if you're using a VISA resource for each "circuit board" then you will need to assign a new resource.
Maybe you can give more details of your setup, etc.
-Khalid
-Khalid
it is using a serial port called free2move to implement...
i have the file of labview...would u mind getting it?
