Data Acquisition for I.C. Engine Using Labview
neo_2004
What data do you want from the engine? What hardware are you using? Does the Engine use an ECM? Is it CAN based?
-Khalid
PS: your smiley's and fonts got all messed up.. maybe you should preview the post before posting.
Tell me what you've got, what you want to do and maybe I can be of some help. I've worked with custom hardware and OEM ECM hardware. CAN would be a pain if you're not getting direct support from the ECM manufacturer and so I would recommend custom NI hardware. The best thing you can do when working with IC engines is to know what you want to do before buying anything. Certain testing requires very fast daq, some things like tuning can be done with relatively slow daq.
sorry, i have a stupid question, please give me an intelligent answer ;-)
what is ECM?
... google finds to many results, e.g.:
- Espresso Coffee Machines
- Enterprise Content Management
- blablabla
ECM, in the automotive industry, stands for Electronic Control Module.
"Electronic Control Modules are subsystems consisting of CPUs and assorted signal inputs and outputs dedicated to controlling a component within the vehicle. They range in complexity from an Engine Control Unit which handles the logic for managing the power-train system efficiency, to an Anti-lock Braking (ABS) Control unit that monitors vehicle speed and brake fluid, to a simple body module that controls the automatic door locks or power windows. In many cases, these modules communicate to each other through such protocols as CAN, LIN, J1850, and J1959. The NI Automotive Test Platform provides a flexible and scaleable test architecture that meets these technical requirements in a cost-effective manner, throughout the product lifecycle, from design validation through manufacturing and service."
Source:
http://www.ni.com/automotive/ecu.htm
what is ECM?
- blablabla
I'm glad you asked for an intelligent answer, or I would have posted a list like:
Electret condenser microphone
Electro chemical machining
Electronic countermeasures
Electronic contract manufacturing
Electronic control module
Elliptic curve method
Error correction mode
Extracellular matrix
Easter candy monster
East coast madness
Everybody craves M&Ms
Eeeeehaaaw, Country Mama!!
</Crazy Mood>
:yes::blink::yes:
Joe (orko)
