jenny Posted March 6, 2006 Report Posted March 6, 2006 hi, can anyone tell me can labview automatic detect a circle or an annulus in a image without i drag the annulus on the image(using ROI tool). i have few images that have a annulus object at different position, is there any way i can detect automatically detect the annulus object ?? please..... :headbang: thanks.... Quote
Mike Ashe Posted March 6, 2006 Report Posted March 6, 2006 If you are using IMAQ Vision you should save off ROI descriptions in a configuration file then at run time use "IMAQ Convert ROI to Annulus.vi" (I usually make a modified version of this) then feed the annulus clusters into "IMAQ Find Circular Edge". This works pretty well, at least when grading Tequila limes :beer: :thumbup: Quote
yazdihr Posted March 6, 2006 Report Posted March 6, 2006 Hi; your question is not clear? Do you want to detect the object automatically or you want to use the ROI automatically? Could you explain a bit more? Hamid hi, can anyone tell me can labview automatic detect a circle or an annulus in a image without i drag the annulus on the image(using ROI tool). i have few images that have a annulus object at different position, is there any way i can detect automatically detect the annulus object ?? please..... :headbang: thanks.... Quote
jenny Posted March 7, 2006 Author Report Posted March 7, 2006 i'm need to automatically detect the object (annulus) in the image/picture. coz i need to extact out the annulus's region out to process... Michael Ashe, Thanks for the advise. i will try... yazdihr, thanks... Quote
Mike Ashe Posted March 8, 2006 Report Posted March 8, 2006 Were you able to find the IMAQ Convert ROI to Annulus.vi ? As I said, I usually use a slightly modified version, basically I make the rotation compoment and input rather than use the integers unpacked from the ROI. Good luck. Quote
crelf Posted March 8, 2006 Report Posted March 8, 2006 I had posted to this thread a few days ago, but it doesn't look like it made it Are you able to add a sample image for us to look at? It might make it easier for us to provide suggestions... Quote
