lorant.dimeny Posted March 8, 2006 Report Posted March 8, 2006 Hello everyone, I would like to obtain a list of the objects AND connections of the block diagram of a VI. In other words, I would like to find out from a VI what objects, subVIs etc. contains an other VI... Is this possible somehow? (e.g. if we have two boolean controls, named Bool1 and Bool2, a boolean indicator, named Bool3, and these three are connected by the means of an AND gate - Bool3=Bool1*Bool2, then I would like to obtain the content of my VI, which is either the formula Bool3=Bool1*Bool2, or something like a date packet Controls: Bool1, Bool2; Indicators: Bool3; Objects: AND gate; Connections: Bool1-1st input of AND gate, Bool2-2nd input of AND gate, Bool3-output of AND gate). The Export Strings function from the Tools menu exports only a tagged list about the objects, without mentioning anything about the connections. Hope you understand my question! Thanks a lot for your help! Lorant Quote
i2dx Posted March 8, 2006 Report Posted March 8, 2006 theoretically this should be possible, but it will be lots of work, to realize this. with the "BlockDiagram" Property-node, you get a array of references to "all Objects", which you can use to build a list of all objects on the BD. then you have to check the connections of the objects among each other and find out which connections exist. Finding subVIs is easy: there is a "subVIs" Property. Quote
lorant.dimeny Posted March 17, 2006 Author Report Posted March 17, 2006 "..with the "BlockDiagram" Property-node, Finding subVIs is easy: there is a "subVIs" Property" hy i2dx, where the heck can I find the "BlockDiagram" and the "subVIs" property nodes? if u have time, can u please give me a tiny example? thanx a lot. lorant Quote
