Sub-VI and default value
Hi everybody,
I have 2 very basic questions about Labview.
1: I have created a VI with a "while loop" and I have a control and an indicator inside and it works. After that, I use this VI as a sub-VI in another program. And now, I doesn't work. I mean, I can't modify the control value dynamically. I think I should use some Local Variable, or something like that. Could you help me please ?
2:Is it possible to Reset a control (for exemple, a numeric control) to its Default Value, while the programming is running ?
Thanks for your answer
Hi foxone,
I'm pretty new to LabVIEW, so I hope what I'm saying here isn't completely wrong.
1. Could you please post your VI? Then I could have a look on it and it would be clearer for me to understand what exactly isn't working as it should be. :)
2. Yes, just right-click on your control and select "reinitialize with default value" (or something similar, I'm working here with the German version of LabVIEW).
Regards, Niko
Hi everybody,
To modify a subvi dynamically you need to disconnect the input terminal from the connector pane.
post-584-1143301771.png?width=400
When a subvi is called all input values that are connected to the connector pane will be set to the incomming value or the default value.
Here is a quick example.
post-584-1143302326.png?width=400
  • 1 month later...
mballa makes a good point about controls with no connection on the connector pane. I often make a control with no connection in subVI GUIs where the subVI gets called multiple times, and on the 2nd and following calls, I want the control to start out with the value that the user last left it with.
Also, you probably want to modify the VI properties of your subVI. Hit ctrl-I, select Appearance, and check "show front panel when called" and "close afterwards if originally closed".
