Mousedown on a Multi-column Listbox Column Header and dragging scrolls up
If you mouse down on a multi-column listbox column header and move the mouse slightly, while keeping it within the bounds of the column headers, it will cause the listbox vertical scrollbar to scroll up. Presumably this behavior is intended for selecting a row and dragging it up, above the upper-most row; in which case, you would definitely want this behavrior. I believe that the fix, is to filter this behavior if the user mouses down in the column header, rather than a (data) row of the listbox.
<OBJECT CLASSID="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000" WIDTH="212" HEIGHT="168" CODEBASE="http://active.macromedia.com/flash5/cabs/swflash.cab#version=5,0,0,0"> <PARAM NAME=movie VALUE="scroll_bug.swf"> <PARAM NAME=play VALUE=true> <PARAM NAME=loop VALUE=false> <PARAM NAME=quality VALUE=low> <EMBED SRC="http://forums.lavag.org/index.php?act=Attach&type=post&id=2498" WIDTH=212 HEIGHT=168 quality=low loop=false TYPE="application/x-shockwave-flash" PLUGINSPAGE="http://www.macromedia.com/shockwave/download/index.cgi?P1_Prod_Version=ShockwaveFlash"> </EMBED> </OBJECT>
Test VI:
Download File:post-17-1143588737.vi
Status: Filed with R&D
CAR#: 3VSACUV2
Download File:post-17-1143588422.swf
