Build option: remove unused poly VI, but DON'T disconnect tydefs
In several of my programs I use the name of a typedef as an identifier.
Since LV 7, there's an option (which is default ON):
"Disconnect type definitions and remove unused polmorphic VI instances"
When building an application (as small as possible), I only want to choose
for the removal of the unused polymorphic VI's
but I DON'T want to disconnect my typedefs.
So why is this one option in stead of two ...
I was last day with a NI tech-rep and he replied that this option is added for backwards compatibility. I think you'll have to replace the polymorphic VI's by the actual subVI's. One method i can think off is to make a source distribution where you have the option activated and then reconnect the typedef....
Which of the two is the best for you is up to you.. ;)
Ton
