Description of native LabVIEW elements
Hi All,
As we all know we must document our code...
For loops I normally use the Label option.
But for larger loops with more code in them I thought of the description item (tip strip is not available)
I prefer the description over the free labels because they only appear if you want....
or well that is what I expected. If you hover over the while loop it will show in the context help, and not my description but the help information about the loop..... :o
Does anyone know how to alter this? Or should this be on the bug list??
Ton
Hi All,
Ton
No, it cannot be altered. It is a feature, not a bug.
I agree - in edit mode, the LabVIEW help should be about the LabVIEW use of the structures, not the custom code that you've put inside it. There was a discussion recently on documentation on the BD - try a search (it was in the last couple of months or so...)
