skfink Posted May 16, 2006 Report Share Posted May 16, 2006 Hi, I'd like to build some software for my pda (Windows Mobile 2005), but I can't find the option to biuld it for a PDA. In the help is written that it's operate->switch Execution target->Select Target with Options But there is no "Switch Execution Target" in my operate menu. Quote Link to comment
crelf Posted May 16, 2006 Report Share Posted May 16, 2006 But there is no "Switch Execution Target" in my operate menu. Have you installed the PDA toolkit? Quote Link to comment
skfink Posted May 16, 2006 Author Report Share Posted May 16, 2006 guess that's it thx Quote Link to comment
crelf Posted May 16, 2006 Report Share Posted May 16, 2006 guess that's it thx np This is what you need: NI PDA Toolkit. Quote Link to comment
Bob Y. Posted May 17, 2006 Report Share Posted May 17, 2006 np This is what you need: NI PDA Toolkit. If you do get the toolkit, be sure to look at this Knowledge Base article for instructions of what all you need. Install everything else before you install the toolkit to LabVIEW. There is an update to the sold toolkit that will let you develop directly for Windows Mobile 5.0. The downside is that you also need to PURCHASE Microsoft's Visual Studio in order to use it. NI is not reselling this, so you will need to go to Microsoft's site to get it. You can also develop for Windows Mobile 2003 without purchasing MS's Visual Studio and it all seems to work fine on Windows Mobile 5.0. Hope that some of this helps, Bob Young Quote Link to comment
skfink Posted June 2, 2006 Author Report Share Posted June 2, 2006 I got all the required tools now and installed it. In the Tools menu of LabView is now a menu item "Build for PDA", but it's disabled. Are there certain circumstances that have to be fulfilled before this option gets enabled? Quote Link to comment
i2dx Posted June 2, 2006 Report Share Posted June 2, 2006 I got all the required tools now and installed it. In the Tools menu of LabView is now a menu item "Build for PDA", but it's disabled.Are there certain circumstances that have to be fulfilled before this option gets enabled? yes, you have to switch to the PDA-Target before this option is availiable and you must have the main-VI of your application open. TGIF CB Quote Link to comment
lchow Posted August 7, 2006 Report Share Posted August 7, 2006 hi, i have the same problem with tis. i even cant find "labview for pda" in execution target after i install labview pda module 7.1. can anyone help?? Quote Link to comment
i2dx Posted August 7, 2006 Report Share Posted August 7, 2006 your labview start screen should look like this: you can build executables for the PDA with the "build for PDA" item from the tools menu: If you don't have a "Pocket PC 20xx Device" or "Pocket PC 20xx Emulatur" that means, you have some issues with your installation. Maybe the Microsoft Tools for PDA Development are missing? I suggest to remove the PDA Module and reinstall it step by step, following the manual. ActiceSync, the MS PocketPC 2003 SDK, etc are important Tools for the PDA Module wich must be installed, if the PDA Module should work properly. Quote Link to comment
